Inventor Forum
Unable to create flat pattern
3 REPLIES 3
matthewgreig
597 Views, 3 Replies
I can't get Inventor to create a flat pattern of the attached sheetmetal part. It's a pretty basic part, just five folds. I'm not getting any error issues - when I go to the flat pattern it just shows the folded part (picture attached).
I assume it has something to do with the way I folded it and the notches, etc. Inv makes to accomplish the fold. But I'm very much an amateur - how do I troubleshoot this?
Matthew
edit: I'm using Inventor 2013 on Win 8.
3 REPLIES 3
jletcher
in reply to: matthewgreig
I can't open your part but I do believe your issue is with this area. your cut goes into te radius of the bend. can you edit the sketch for the leg fold cut out so I can see it.
coreyparks
It has something to do with how the folds all come together in the middle I think.  I have had problems with the fold feature creating things that couldn't flat pattern so I rarely use them.  I rebuilt the part using other methods and it flat patterns fine now.  I wouldn't have used the fold feature but I didnt want to redo the entire part.  Take a look and see if this method will work for you.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
matthewgreig
in reply to: coreyparks
James, not sure what you mean by the leg fold cut out sketch, but you guys are right that it's the folds. Corey's redo using a series of flanges for the "wings" allows it to flat out just fine.
Thanks for the tips - I'll avoid the fold feature when I'm doing close tolerance stuff from now on.
