Inventor Forum
Unable to Create Component
4 REPLIES 4
batone79
979 Views, 4 Replies
Hi, first sorry for my english, now a have a typical error to insert in my assambly a item from my content center, reciveing a erro like "unable to create component", i´m looking for a solution inside forums and find a solution but didn´t work for me, the solution watched and did for me as deleted of the content folder "CACHE" in my computer C:/....all users/inventor..../cache.
I use AI2009 with SP1.
Where is the problem?. What can i do, delete all families from content center and upload again?.
Thanks!.
4 REPLIES 4
mflayler2
in reply to: batone79
Sounds like your Content Center cannot find the standard template or you modified the standard template. If you remove them or remove materials from the Standard template I often see this problem occur.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
I cannot save cc part as a custom part in some projects, but in some other project work. i use inventor 2012.
office
I have the same problem with Inventor 2011 on windows 8. I had also read other posts and nothing works. Only "features" from category view could be placed in asembly. What is the solution?
office
in reply to: office
Yes some guys had solved the problem. It works in my case as well. In regional language and region format options in windows should be replaced with English (US).
