I'm unable to apply coincident constraints to spline points with projected points as reference. 5 out of the 7 points were successful. Is there a reason I'm not able to apply coincident constraint to the remaining 2?
Steps involved..
1. Projected spline and points from earlier sketch (sometimes I keep a backup of the orignial spline for reference)
2. Selected spline and selected break link (I'm breaking the link so I can split the spline into 2 segments, allowing me to use the spline segments as guide rails when creating a loft)
3. Applied coincident contraint to points but 2 points create an error
Hi Jusin,
Right click on the spline and select show degrees of freedom. Do you get allowable movement on the 2 points that you cannot constrain?
Can you upload the file so I can take a look?
Chris
