Inventor Forum
uh-oh (slow down)
17 REPLIES 17
Message 1 of 18
504 Views, 17 Replies
uh-oh (slow down)
Great, now I'm starting to experience a bit of a slow down. The yellow dot
is beginning to lag the cross hairs. And things in general are moving as if
a drop of syrup was lodged in my computer... 😞
Don't know why all of a sudden.
Quadro 4 700XGL with the autodesk recommended drivers (2492)
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
17 REPLIES 17
Message 2 of 18
jmartzig
IV6 musta known that you went to see a demo of that "other" PROfessional software. -Joe
Message 3 of 18
MechMan_
LOL.
Sean, a bit obvious but does to continue after a reboot? Does it happen in just one file or several files?
MechMan
Message 4 of 18
slightly better after a reboot (as with all other
version of IV).
Turned on the "warn if not using a certified card"
and it tells me I may need registry updates and that I'm not using a certified
card.  Well I am and I'm using the recombined graphics.  I'm convinced
that message is about worthless.
I don't see any registry updates on the graphics
site however.  I vaguely remember a post about this but can't seem to find
it.
Joe you are right.  Apparently she's angry
about me seeing that other CAD package.  Really baby, nothing
happened I promise..<g>
Sean Dotson, PE
href="http://www.sdotson.com">http://www.sdotson.com
remove all #s from
email
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
LOL.
MechMan
Message 5 of 18
jmartzig
word on the street has it that she heard that she may be used as a secondary CAD girl. ha ha.
Message 6 of 18
GOOD!!! Now you are in the same boat as alot of the rest of us. LOL. We've
got a couple of Quadro4 900xgl cards and they are running awful. Our worst
workstation has a Synergy II and it runs IV6 the fastest, go figure. Maybe
since you are having trouble Autodesk will take notice and help the rest of
us poor souls out. Keep us informed.
"Sean Dotson" wrote in message
news:992C35C1EB894A30550C74E103765C84@in.WebX.maYIadrTaRb...
dot
if
> Sean Dotson, PE
Message 7 of 18
MechMan_
Boy Sean, how does it feel to be a "marked man"? It sounds like some have just been waiting to hear a bad experience from you.
MechMan
Message 8 of 18
Sean,
I've seen that "may need registry updates and that
I'm not using a certified card" message also, even though I'm up to date and
certified.  I just turned off the warnings.  I believe I saw some post
that others were also seeing this.
My graphics card is ATI fire GL2.
Keith
version of IV).
card" and it tells me I may need registry updates and that I'm not using a
certified card.  Well I am and I'm using the recombined graphics.
I'm convinced that message is about worthless.
find it.
Sean Dotson, PE
remove all #s from
email
LOL.
MechMan
Message 9 of 18
we always mock that which we don't understand
<vbg>
I don't blame Eric.  It seems for a while I
was in the minority of those that could get it to work.  It's still useable
just a bit annoying.  Hopefully it doesn't get worse and SP1 will clear it
up..
Sean Dotson, PE
remove all #s from
email
Boy
MechMan
Message 10 of 18
One thing I have noticed from reading the NG is the
quadro's causing speed problems.  Maybe we can create  a list of
cards, drivers and problems seen.  It may help to narrow the problem
down.
Kathy Johnson
understand <vbg>
useable just a bit annoying.  Hopefully it doesn't get worse and SP1 will
clear it up..
Sean Dotson, PE
remove all #s from
email
Boy
MechMan
Message 11 of 18
Okay, I'm posting this again!
Official word from Inventor Graphics
team:
"We put out this warning for cards which are
certified but which may in the future be able to run better with other drivers
or registry settings.  Customers can always safely ignore warnings if they
don't see any problems -- the warning is of a possible cause in case they do see
problems.  The message can be turned off with the check boxes in the
Tools>Application Options>Hardware tab."
Glenn
Inventor Part Modeling
Sean,
that I'm not using a certified card" message also, even though I'm up to date
and certified.  I just turned off the warnings.  I believe I saw
some post that others were also seeing this.
Keith
other version of IV).
graphics site however.  I vaguely remember a post about this but can't
seem to find it.
Sean Dotson, PE
remove all #s
from email
LOL.
MechMan
Message 12 of 18
I've a syn III, I was to upgrade......to what? might be a slug and out
of fashion but I'll keep that lump of granite........it is....... 🙂
Laurence,
"Eric Zirkle" <@> wrote in message
news:66174060BBEFFBC39DC49393AB8DCF9C@in.WebX.maYIadrTaRb...
We've
Maybe
of
> dot
as
> if
> > Sean Dotson, PE
Message 13 of 18
Sean I feel your pain.
Quadro 4 900XGL
Same thing was happening here. Uninstalled 6. Reinstalled 6 and slowdown went away. Unfortunatly 4 power exits an hour have not.
Message 14 of 18
I'm running a GIII and haven't seen performance
problems yet (now I've done it) haven't seen the crashes either ... maybe two
since R6 got here (talk about having done it now, is that called a fearless fool
or what?). <G>
~Larry
Sean
I feel your pain.
Quadro 4 900XGL
not.
Message 15 of 18
Your right,..... you have done it.... I am going to make a midnight visit to
borrow that machine for a while I still can't get mine going good
enough to use full time. Thought I had it when the files migrated Ok, but
then after working for a while when I tried to save it came up with some
sort of error message and wouldn't let me. I am far enough behind now I
couldn't risk it anymore.
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
http://www.MyMcad.com/KWiK/Mcad.htm
"Larry Caldwell" wrote in message
news:82A0FD6362C98C4D72E9D734126C043D@in.WebX.maYIadrTaRb...
> I'm running a GIII and haven't seen performance problems yet (now I've
done it) haven't seen the crashes either ... maybe two since R6 got here
(talk about having done it now, is that called a fearless fool or what?).
> ~Larry
Message 16 of 18
DJSpaceMouse
Keith-
If the optimized application in the Windows advanced display settings isn't set to "Autodesk Inventor", Inventor "sees" the FireGL2 driver ID as a one that is not certified. If it's set to "Autodesk Inventor", Inventor sees the graphics driver ID as "ATI\Fire GL23 SIMD\1.2.2088", which is certified. With it set to "Default", it's "ATI\Fire GL2 Pentium III (SSE)\1.2.2088" (your PC may be different).
Oddly enough, though, for older releases of Inventor, Autodesk recommended the "Default" setting, not the "Autodesk Inventor" setting.
Message 17 of 18
Sean,
Hopefully you realize I was just
kidding.
understand <vbg>
clear it up..
Sean Dotson, PE
remove all #s from
email
Boy
MechMan
Message 18 of 18
of course I do... we are very tongue in cheek
around here...<cheers>
Sean Dotson, PE
remove all #s from
email
Sean,
kidding.
understand <vbg>
I was in the minority of those that could get it to work.  It's still
will clear it up..
Sean Dotson, PE
remove all #s
from email
Boy
MechMan
