Inventor Forum
UCS
8 REPLIES 8
Message 1 of 9
1590 Views, 8 Replies
UCS
Is there a way to reorient the ucs to the part? I've tried the help, but not getting it.
8 REPLIES 8
Message 2 of 9
JDMather
Yes, but in 12-13 yrs of using Inventor - I have never had to re-orient the UCS except to fix geometry done by others.
Can you attach file here where this would be useful?
Message 3 of 9
swalton
Are you asking about the default orgin geometry? If so, no. That is fixed.
There are two options if you want to re-orient your part geometry with respect to the default origin.
1. Redefine all your features to use the correct origin planes
2. Use the move body command. Note that this command can both move geometry and rotate it.
I always plan my first feature in a part so that the origin geeometry is useful for later modeling.  This takes some thought about how the part will fit into assemblies and how the assemblies fit into the real world, but is helpful when other people (or you after a few months/years) pick up your models.
Steve Walton
Inventor 2023
Vault Professional 2023
Message 4 of 9
in reply to: swalton
Actually I'm putting the file into Meshcam as an stl file. I have some flexibility in that program to reposition the ucs. But its a little tricky. I thought if I could just change it in Inventor it would be easier.
Message 5 of 9
johnsonshiue
Hi! There are two type s of part-level UCS: parametric and associative. The type depends on how the UCS was created (redefined). If you pick a vertex (workpoint or model geometry) as the first pick, the UCS will be associative. Inventor will wait for you to pick two more vertices (second pick defines X axis; third pick defines Y axis).
If the first pick is somewhere in the graphics window, not attached to a vertex, it will be parametric. There will be three parameters created with the UCS. Each controls the distance between the UCS and global origin with respect to X, Y, and Z.
In your case, it sounds like you would like to create or redefine an existing UCS to an associative UCS. Simply right-click on the UCS in the browser -> Redefine -> pick a vertex (as the origin of the UCS) followed by two more picks of vertex to define X and Y.
Let me know if it works for you.
Many thanks!
Software Test Engineer
Message 6 of 9
JDMather
I think you are actually referring to a "world" (unchangeable) coordinate system rather than a user coordinate system.
The stl file would use the absolute system.  (At least I think it would - I didn't test this out.)
You can rotate your part with the Move Bodies command before exporting as *.stl
Or if it is a simple part, it might be as simple as right clicking on the first sketch and redefine the sketch plane.
Message 7 of 9
Curtis_Waguespack
Hi Dferr34,
These links might help. I'm not sure if you'll get your STL file to use the UCS, as JDMather mentions it's likely to use the WCS:
User coordinate system (UCS)
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-FF15BB0D-5FE9-45F9-92FD-D70A3F6A8FD0
Create user coordinate system (UCS)
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-D25B95E8-0683-4846-8A2E-5BF2EA201F65
Redefine the user coordinate system (UCS)
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-61D274D6-9F7B-4706-935A-BAF36C8D2DD2
Here's a link showing the Move Body tools in action, as others have mentioned:
Change The Origin of a Model
http://inventortrenches.blogspot.com/2011/06/change-origin-of-imported-model.html
I hope this helps.
Curtis
Message 8 of 9
in reply to: Curtis_Waguespack
Thanks for the help! This is such a simple part I just redrew it the way I wanted. I'll try some of the methods posted, when I get a chance. Thanks!
Message 9 of 9
Move bodies worked. Thanks!
