Hello all..
i am trying to find a way to find U-Bolts for inventor.... does anyone know how to find parts of U- Bolts and sizes.... since the library of Inventor dont have....
thx.. 🙂
Solved by Cadmanto. Go to Solution.
Have you checked cbliss.com
http://cbliss.com/inventor/Parts/Hardware/index.htm
GrabCAD ?
https://grabcad.com/library?per_page=20&query=u-bolt
McMaster-Carr?
What are the specifications?
Just model your own.. takes seconds.
I used to download mine from McMaster-Carr in the Solidworks format and bring them into Inventor. They needed minor contraining, but worked fine.
http://www.mcmaster.com/#u-bolts/=ruixag
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
HI... all
in the " Hardware " sit dont have almost nothing about U bolts.
grab cad... also almost nothing...
But in MCmaster.... a lot... and very very usefull stuff...
but i did not understand very well what you mean about the mirror... can you explain please... i am guessing that the mirror that you are refering to, is not the mirror tool of inventor.. or is it ??
Thx...
@Anonymous wrote:HI... all
Thx...
McMaster-Carr is a great resource and I use them all the time, we also buy a lot from them.
BUT their models tend to have way more detail than required and a U-Bolt would be a prime example. The file you will download will be quite large. No trouble in a small assembly but in a large one with a lot of their parts the large files can cause a performance loss.
I didn't say "Mirror" , I said "Minor". In reference to constraining. I found when I downloaded the U-Bolts from MMC that the nuts free floated and needed to be contrained. That is what I was refering to.
