Inventor Forum
Two Different Border & title-block Colors
3 REPLIES 3
Paul-Mason
821 Views, 3 Replies
I use two different measuring system IMPERIAL and METRIC.
What I want is to be able tell at a glance, by having different color border and Title-block Text  is which one of the system of units I'm using
So what I'm wanting to do is create a Metric Sheet template with on color, Border, Title Block Text and a different color for the Imperial.
I've tried changing the color using the Style Center but that affects both templates, I've tried editing the title-block text saving the template but on opening it has changed back to the defaults set in the style settings and dose not hold those that I set.
What I don't what to be doing is changing them after opening, as at some stage I'll forget.
USING Inventor Pro 20012
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
3 REPLIES 3
SBix26
in reply to: Paul-Mason
I think you just need to add a couple of new line styles to your library with the alternate color, then use those for the alternate title block & border.
Sam B
Inventor 2012 Certified Professional
Please click "Accept as Solution" if this response answers your question.
Inventor Professional 2013 SP1.1 Update 1
Windows XP Pro 32-bit, SP3
HP EliteBook 8730w; 4 GB RAM; Core™ 2 Duo T9400 2.53 GHz; Quadro FX2700M
SpaceExplorer/SpaceNavigator NB, driver 3.7.18
still waiting for a foreshortened radius dimensioning tool in Drawing Manager
Paul-Mason
in reply to: SBix26
I'm already doing it like that, but some time, more than often I forget to change the things.
I was kind of hoping that there would be a way in which to create a template for each, having the template do the work for me.
Inventor 2023 Pro
HP Z420 workstation
SBix26
You could add a second Standard to your styles that would have a different set of Object Defaults, perhaps?  Or in the alternate template, have an alternate title block & border defined that use the alternate linestyles?  I think this can be pretty easily done, but it's hard to get it figured out without actually working with your files and library.  Any chance you could post your two templates?
Sam B
