Inventor Forum
Two Colored Stripped Sweeps
6 REPLIES 6
407 Views, 6 Replies
I have made hundreds of feet of piping using general sweeps and typically select the properties of each sweep to properly color code the pipes. I now have a model where I need to make a length of pipe stripped colored (say blue and red) for ease of visual identification. How do I do this? I can't find anywhere to tell Inventor (2012) to make my color "two toned". Thoughts? I'm using AutoCAD Inventor 2012.
-Thanks
6 REPLIES 6
ampster401
one guess would be to create multiple split surfaces along the pipe, then you can individually assign color to each split.
Alot of work I'm sure but I don't know any other way.
in reply to: ampster401
Thanks ampster.... Although a tedious method, its does work. Appreciate it!
mpatchus
Why not simply create a striped color style?
You can adjust the size of the stripes by changing the scale of the texture image.
You could also have the stripes run diagonally if you choose by changing the angle of the texture.
This would also keep your material properties valid.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
in reply to: mpatchus
PERFECT! Awesome Idea! Just tried it out and crazy easy. Thanks!
Spoiler
Spoiler
Smiley LOL
WHolzwarth
Well, Inventor is stepping forward. Perhaps velocity could be improved ..Smiley Wink
With 2015 it's no big deal.
Walter
Walter Holzwarth
