Does anyone know if its possilbe in Inventor to twist a sheetmetal part? Or to make a flat pattern of a twisted shape?
Solved by kelly.young. Go to Solution.
Solved by CCarreiras. Go to Solution.
@abobyrius wrote:
...this is an architecturial intent to be made out of solid piece of copper.
Hi @abobyrius,
I would think that the part modeled without the twist would give you a flat pattern accurate enough for your manufacturing needs. So you could likely just create a twisted version for use in the assembly, and an untwisted version for figuring out the flat pattern.
I hope this helps.
Curtis
Edit: attached is an example file created with Inventor 2017 using the sheet metal tools
@abobyrius you have gotten some pretty good information about the limitations and expectations of the sheet metal environment. If you really want the flat pattern for your copper piece this is how I would go about it:
Not perfect, but if you make a temp piece, trim, re-document, you should get a repeatable process.
Hope that helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
