Im trying to reproduce the part attached. Its a rectanglar alumin tube. .320 x .180 approx an inch long.
I tried lofting 2 sketches but the result does appear like the attached image.
What command should I be using?
Solved by CCarreiras. Go to Solution.
Yeah I thought it had something to do with the rails.
A simple loft does not achieve what I want. I will give it a try. Thanks
Thats it
You need to use point mapping I beleive
Correct?
I got the general idea, just need a little practice.
