Inventor General Discussion
New Member
achupick64
Message 1 of 4 (415 Views)
Twist an Object
415 Views, 3 Replies
02-11-2013 01:26 PM
Is it possible to twist a bar shape. I have the inventor part file as well as a jpeg file of what the device should look like. Can anyone help me?, is it even possible with inventor or fusion.?
*Expert Elite*
JDMather
Message 2 of 4 (410 Views)
Re: Twist an Object
02-11-2013 01:44 PM in reply to: achupick64
Yes, use Coil (helix) command.
You attached an assembly file (*.aim).
Assemblies without parts (*.ipt) are useless.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
achupick64
Message 3 of 4 (393 Views)
Re: Twist an Object
02-11-2013 02:02 PM in reply to: JDMather
Here is the whole assembly. How would I set the helix with a slight twist then?
*Expert Elite*
JDMather
Message 4 of 4 (361 Views)
Re: Twist an Object
02-11-2013 05:53 PM in reply to: achupick64
Your sketch isn't centered or fully constrained.
I don't have Inventor 2012, but I assume this is something like what you are after (I didn't bother to fix the alignment of the plates).
You will need a flat start and end to match the slots cut square to the flats.
Announcements
Need installation help?
