Inventor Forum
Twist an Object
3 REPLIES 3
achupick64
893 Views, 3 Replies
Twist an Object
Is it possible to twist a bar shape. I have the inventor part file as well as a jpeg file of what the device should look like. Can anyone help me?, is it even possible with inventor or fusion.?
3 REPLIES 3
JDMather
in reply to: achupick64
Yes, use Coil (helix) command.
You attached an assembly file (*.aim).
Assemblies without parts (*.ipt) are useless.
achupick64
in reply to: JDMather
Here is the whole assembly. How would I set the helix with a slight twist then?
JDMather
Your sketch isn't centered or fully constrained.
I don't have Inventor 2012, but I assume this is something like what you are after (I didn't bother to fix the alignment of the plates).
You will need a flat start and end to match the slots cut square to the flats.
