Inventor Forum
Twist A Part
11 REPLIES 11
Message 1 of 12
chrisrodway
1313 Views, 11 Replies
Twist A Part
I’m trying to twist a flat part, any ideas how I would go about doing it?
I have modelled the part in its flat state and need to twist it around an axis; please find attached a picture of what I’m trying to model and an ipt file. The sizes and holes have been changed for IP reasons.
Any ideas or help is appricated
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Tags (4)
11 REPLIES 11
Message 2 of 12
JDMather
in reply to: chrisrodway
Helical surface created with Coil feature.
Trim the surface.
Thicken.
Will not exactly true (on cut edges) to the the distortion due to bending.
Message 3 of 12
chrisrodway
in reply to: JDMather
Thanks for the reply,
This way of modelling the part had crossed my mind, but how do I then go about adding hole detail so there in the correct orientation?
That’s why I thought it was better to start with the flat part and somehow bend it if possible in inventor?
Any thoughts
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Message 4 of 12
JDMather
Here is an example - I didn't have time to figure out a more elegant technique.
The Thicken of a surface does add some distortion to the holes, but not 100% true to real world result.
Message 5 of 12
Paul-Mason
See the attached, I've just use small sizes for it, It was also created in IV 2012 but it'll open in any newer versions with a warning just accept the changes from older to newer version. hope it of some help.
Inventor 2023 Pro
HP Z420 workstation
Xeon 3.7Ghz CPU 8 Cores, 64 GB Ram
64bit (The Garbage known as) Windows 10 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
Message 6 of 12
mrattray
in reply to: Paul-Mason
You forgot to attach your file.
Mike (not Matt) Rattray
Message 7 of 12
Paul-Mason
in reply to: mrattray
Sorry about that. I don't know what's going on but either Autodesk System or IE 10 is striping the file off, it's happen a few time recently, so I've used GOOGLE CHROME this time  Here it is I hope.
Are the hole parallel to the face, only it's abit difficult to tell or see any ont the example that was posted?
Inventor 2023 Pro
HP Z420 workstation
Message 8 of 12
Paul-Mason
With the holes paralle to the face, the work plain is obtained by picking the three point shown
Inventor 2023 Pro
HP Z420 workstation
Message 9 of 12
chrisrodway
Thanks for the help guys I've modeled it using the ideas from both your models
Thanks for the assistance and effort
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Message 10 of 12
mrattray
Just FYI:
There's a "known problem" with the board and certain file extension types, particularly .dwg. I haven't ran into yet myself, but I believe others have been having success zipping the file first.
There's also other "known problems" with both the board and the AutoDesk website in general using IE10. I use FireFox, but apparently downgrading to IE9 works as well.
Message 11 of 12
Paul-Mason
Pleased you found the post of us both helpful, and came up with a solution.
I would, and I think JD might be as well, interested to see how you resolved this, it's amassing how many right answers that can be, using different methods, to solve a problem like this.
I though there may be some problems with attached files, as on several occasions some of my files have been stripped I though that I forgot to attach or that they may have been suspect in some way by the Autodesk system, I do know that posting more than one file is virtually impossible with the carp know as IE10 that why I now use Google if I'm posting /attaching files to this site and  group
Inventor 2023 Pro
HP Z420 workstation
Message 12 of 12
chrisrodway
I found the best way to model a part like this is to coil a surface into the appropriate shape.
Project the holes from a flat development sketch on an offset plane above and trim down.
This gives the holes in the right orientation on the coiled surface.
Thicken the part and you have an accurately modelled part.
Cheers
Chris Rodway
Design Engineer
Sheffield, UK
Tags (3)
