Inventor Forum
Tutorial Problem
14 REPLIES 14
Message 1 of 15
lemaycj
694 Views, 14 Replies
Tutorial Problem
I'm still going through the tutorial.  I'm only on Create the part from Scratch.  Obviously I have Options not setup as in the tutorial because simple thing lile the coordinate system indicator was on in Sketch and preventing me from picking the 0,0,0 point.  When I try to add a constraint to my rectangle to center it over 0,0,0 it gives me a message that it would be overconstrained and won't do it.  I can go on and add equations to the general dimension.  But the simple task of constraining isn't working.  I've gone back to the Constraining exercises but it won't work for me here....
What do I have to do to make this centre over the axis??
14 REPLIES 14
Message 2 of 15
in reply to: lemaycj
Like this.
Message 3 of 15
JDMather
Following the steps in the Tutorial -
On the Constraints tab click Horizontal
then click point 1 (the green projected origin) and point 2 then midpoint of the left vertical line.
What happens?
Message 4 of 15
lemaycj
in reply to: JDMather
I followed the video pausing at every step to check the messages against what I get.  As soon as I pick a line on the rectangle, right away a message of overconstraining comes up.  I started over 4 times with the same results every time.
It must be something in the setup of Inventor or Inventor Options that is doing this.
It's a really simple task and it's really bothering me that I can't do it.
Message 5 of 15
Have you closed Inventor and restarted?
Message 6 of 15
lemaycj
I changed a setting in Inventor/Options/Sketch: Overconstrained dimensions to Apply driven dimension.  Re-started Inventor, new part created with the same template.  As soon as I click on the line on the rectangle the message window appears: "Autodesk Inventor- Create Constraint: Cannot constrain or dimension reference or fixed geometry".
Message 7 of 15
I edited the sketch on the part you posted with no problems.
Not sure why you are having this problem.
Message 8 of 15
JDMather
It sounds like you are clicking twice on projected geometry.
Message 9 of 15
lemaycj
This is what I have been doing, over and over:
I start a new part, it opens up in sketch mode already and I click on rectangle, pick two points  across for the latter, hit ESC, then horizontal constraint, I then pick the 0,0,0 location, then a vertical line on the rectangle and bang the message window appears.  I just don’t know what it coud be…
Message 10 of 15
kstate92
When creating the rectangle, do any constraint glyphs (horizontal, vertical) appear?  After placing a rectangle, what results when selecting autoconstraints?
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 11 of 15
JDMather
That is where you are going wrong - don't pick the vertical line - pick the midpoint of the vertical line (it will highlight green dot when you get close).
Think about the logic - you are not trying to make the vertical line horizontal (which is why you get an error - it is obviously already vertical), you are trying to make the MIDPOINT of the vertical line horizontal to the origin.  So logical, so easy!  You will get there.
Message 12 of 15
lemaycj
in reply to: kstate92
When creating a rectangle, no constrain glyphs show up at all.  I hit F8 and then they show up.  Both vertical lines (left and right) show parallel glyphs. The bottom line also has a parallel.  The top line has a parallel and a horizontal constraint.  The center point is yellow and has the project geometry.  Also all corners of the rectangle have yellow dots.  The upper right corner also has a perpendicular.
Message 13 of 15
JDMather
yes.
Message 14 of 15
kstate92
That's what I see too.  This leaves only length, width, and positon w.r.t. the auto-projected origin point.
KState92
Quadro P2000
Message 15 of 15
lemaycj
ok.  Beyond stupid.  I got it now. Duh!  Sorry for the hold-up.  I will carry on now.....Thanks....again...!!
