I just installed Inventor Professional 2014 and I can't find the tutorial_files in the Projects dialog box. Do I have to download them separately from somewhere? Thanks for any help!
Solved by CCarreiras. Go to Solution.
Hi!
Yes, you have to download and install the tutorials files.
Check it...
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=21952055
Tip: Also you can download the "Offline Help"
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=16463987
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
