Inventor General Discussion
Cadmanto
Message 1 of 6 (678 Views)
Turning on Visibility of Line Segments in Drawings
678 Views, 5 Replies
10-01-2012 12:46 PM
In drawings there are a lot of times where I turn off the visibility of certain line segments to make the view look cleaner.
What if I was to reverse the visibility of these lines segments down the road?
How is this done?
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
RMB on view.
Select "Show Hidden Edges"
The edges whose visibilty has been toggled off show up in red. Select them to toggle each segments visibility back on.
Sorry, I've never figured out how to screen cap the RMB menu.
mrattray
Message 2 of 6 (673 Views)
Re: Turning on Visibility of Line Segments in Drawings
10-01-2012 12:50 PM in reply to: Cadmanto
RMB on view.
Mike (not Matt) Rattray
Distinguished Contributor
Ryan.Martinez
Message 3 of 6 (671 Views)
10-01-2012 12:52 PM in reply to: Cadmanto
I think this is what your after.
Then right click. All your hidden lines should show up red. Then click show all and they should be back.
Hopefully that makes sense and is what your after.
PDS 2014
PDS 2015
Ryan.Martinez
Message 4 of 6 (670 Views)
10-01-2012 12:53 PM in reply to: mrattray
print screen the paste into paint =)
PDS 2014
PDS 2015
Cadmanto
Message 5 of 6 (641 Views)
10-02-2012 05:35 AM in reply to: mrattray
Thanks Mike that will work.  Simple over sight.
As far as capturing the RC menus in an image, what I do is have the snipping tool open, select "New"
then hit the "Esc" key, select back into the program screen you want to capture and then hold down the "Ctrl"
key and hit the "PrtScn" key.  Then will freeze the RC menu and bring the snipping tool back up to crop and capture the image you want.  Like I did below.
Best Regards,
Scott McFadden
mrattray
Message 6 of 6 (633 Views)
10-02-2012 06:02 AM in reply to: Cadmanto
Cool, thanks!
