In this model (Inventor 2015 Frame Generator)
the XZ Plane (actually an offset of it) remains stubbornly visible. Although I can see where if is turned on, there is no Visibility switch.
How can I get rid of it?
Solved by blair. Go to Solution.
In the Browser Window, select the Work Plane and RMB to bring up the properties, you can then turn it's visiblibty off. You can also toggle gobally the work planes from the View Tab.
