Inventor Forum
Turning off all Workplanes?
5 REPLIES 5
223 Views, 5 Replies
Is there a quick way of turning off all workplanes in assembly without having to go into each part to turn them off? Thanks, Ben V.
5 REPLIES 5
VIEW, OBJECT VISIBILITY, uncheck ORIGIN PLANES. Sean has a macro to do this better though. -- ______________ Rui ruivaz@cadmais.pt www.cadmais.pt "Ben V" wrote in message news:3fdf54ec$1_7@statler... > Is there a quick way of turning off all workplanes in assembly without > having to go into each part to turn them off? > > Thanks, > > Ben V. > >
Go to View, Object Visibility, and uncheck User Work Planes or Origin Work Planes depends on which you use. -- Derek Sevier Mechanical Design Engineer Quality Corporation derek dot s at donkeyforklift dot com www.donkeyforklift.com "Ben V" wrote in message news:3fdf54ec$1_7@statler... > Is there a quick way of turning off all workplanes in assembly without > having to go into each part to turn them off? > > Thanks, > > Ben V. > >
If you go here and download Hide/Show Features Macro it works really well, handy tool from Sean. http://www.sdotson.com/vba.asp "Ben V" wrote in message news:3fdf54ec$1_7@statler... > Is there a quick way of turning off all workplanes in assembly without > having to go into each part to turn them off? > > Thanks, > > Ben V. > >
Funny, I was just going to post the same question. You folks are good, you can read my mind.
Ed
You can click View>Object Visibility>Work Planes like others have suggested above. But if you will notice to the right of the last window in the previous command, there will be something like "Ctrl+[". This is the shortcut that will toggle on/off the workplane. I have mine set as "Alt+[" and "Alt+]" for origin planes and user planes. When I want to turn them on, I press ALT+ [ ], and they are turned off, press it again and they are turned back on. Takes about 1 second to turn them all off, then back on again. You can customize them to whatever you want by right clicking in the menu bar and chose "Customize", then click the Commands tab. Hope This helps, Kirk "Ben V" wrote in message news:3fdf54ec$1_7@statler... > Is there a quick way of turning off all workplanes in assembly without > having to go into each part to turn them off? > > Thanks, > > Ben V. > >
