You can click View>Object Visibility>Work Planes like others have suggested
above. But if you will notice to the right of the last window in the
previous command, there will be something like "Ctrl+[". This is the
shortcut that will toggle on/off the workplane.
I have mine set as "Alt+[" and "Alt+]" for origin planes and user planes.
When I want to turn them on, I press ALT+ [ ], and they are turned off,
press it again and they are turned back on. Takes about 1 second to turn
them all off, then back on again.
You can customize them to whatever you want by right clicking in the menu
bar and chose "Customize", then click the Commands tab.
Hope This helps,
Kirk
"Ben V" wrote in message
news:3fdf54ec$1_7@statler...
> Is there a quick way of turning off all workplanes in assembly without
> having to go into each part to turn them off?
> Thanks,
> Ben V.
