Is it possible to transform a part (in the form of a plate) into a surface?
What I am trying to do, is produce a series of surfaces from a series of plates to build a massless representation of my model with no thicknesses, just the geometry. So for example, if I had a part which was a square plate, 50mmx50mm and 10mm thick, is there anyway to transform this to a surface located at the 5mm half way point?
Any help is greatly appreciated.
Solved by Ktelang. Go to Solution.
Yes, you can
Use thicken/offset with surface option.
Then in surface bodies folder you will find the new surface created.
switch to the manage > Author> Export objects command and export the surface.
Open a new part and derive > reuse surface> and create the derived part.
Hope that helps
Thanks a lot, thats very helpful.
Although I'm struggling to find the reuse surface option after ive exported the surface and gone to derive in a blank new part file? How do i get to this?
Sorry my bad,
the icon with the + sign next to the surface body is
"include". Ignore the "reuse surface" frommy previous post
Choose these options
