How do I turn off the origin indicator in the middle of the model shown in the attached jpg image? I know it is not the Center of Gravity Indicator and everything I have found in application options controls the origin indicator in the lower left corner. This is the only assembly that this has occurred with and I haven't been able to turn it off. Also, the indicator is not in either of the ipt files that make up this assembly, iam, file.
Best Regards,
Mike
Solved by m.granata. Go to Solution.
@m.granata wrote:
....I know it is not the Center of Gravity Indicator ...
Hi m.granata,
It looks like the Center of Gravity triad to me, can you confirm that you've tried this:
On the ribbon, click View tab > Visibility panel > Center of Gravity button.
Related link:
http://help.autodesk.com/view/INVNTOR/2014/ENU/?guid=GUID-E8FFE71F-3F0D-4F9F-AAB7-2341B8BCAA6D
I hope this helps.
Curtis
Curtis,
I've tried that several times. I just read the instructions in the link you referenced and still no luck. What happens is an additional Triad indicator is diplayed when I follow your instructions. This troubling indicator gets displayed everytime when I insert the part into the assembly even though the indicator is not displayed in the part file.
Best Regards,
Mike
Something was damaged in the part file. I deleted the part file and replaced it with an earlier archived copy of it. The issue no longer exists.
Best Regards,
Mike
