Inventor Forum
Turn Off Command Message Window?
3 REPLIES 3
nathan.anderson
277 Views, 3 Replies
Is it possible to turn off the command message window?
It's annoying because I know that the four insert commands need fixed and each time I fix one I can the same message over and over until they are all fixed. Yes I know i could just delete them all and re-create them but that is not efficient or desireable in some cases. I would like to turn off this windown and never show it again. The warning icons in the model tree and the design doctor red cross provides enough feedback for advanced users. I'm hoping there is a setting or a config file I can change to suppress this Command Message window.
Nate
3 REPLIES 3
lkrenzler
in reply to: nathan.anderson
+1.  I'd like to know too.  Drives me nuts after a while.
Inventor Pro 2019 - Win. 10 - GeForce GTX 1080 .
Cadmanto
Nate,
Try this setting.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
t_stramr
If you know that you will fix set of failing constraint and you don't want to see error box for remaining failures after each fixed constraint you can defer automatic update of your dataset after each operation and update your assembly manually. In Application Options activate Assembly Tab and check on the first item named Defer update. This suppresses automatic update and gives you chance to update manually by Update button on Manage ribbon.
Robert
