Inventor General Discussion
Valued Contributor
trenthoskings
Message 1 of 6 (222 Views)
tube % pipe versus individual pipes
222 Views, 5 Replies
12-16-2012 03:44 AM
I habe a machine which required various size pipes.The machine area is 7m x 2m.....I ususally design each individual pipe...is this better to do with pipe and tube or should i continue to create each pipe individually....I have created all the valves which i use in the machines......can these be inserted using Pipe & Tube?
Any advantage of pipe and tube over individual creation of pipes in machines of this size
Thank you
TH
blair
Message 2 of 6 (207 Views)
Re: tube % pipe versus individual pipes
12-16-2012 09:55 AM in reply to: trenthoskings
The T&P module is really just a "short-cut" and has some specific tools to aid in 3D sketching for the create of the T&P runs.
If you are just using straight pipes and have placed all your fittings, maybe think of using the Content Center for your pipes. You can simply RMB on the CC pipe within the assembly and change it's size or length from the screen pop-up dialogue box.
It also has a number of benefits in the IDW's BOM as well.
IV2015 SP1 PDSU / Sim Mech 2015 r1 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 344.60
SpacePilot Pro 3.06.109
Delta Tau Chi ΔΤΧ
cbenner
Message 3 of 6 (178 Views)
12-17-2012 06:38 AM in reply to: trenthoskings
In my humble opinion, the benefits of T&P vs individual pipes using standard constraints depends greatly on the amount of piping you need to run.  If your machine is heavily piped as ours are, they are a nightmare to do with standard constraints.  T&P does have some limitations and can be a hair pulling experience at times... but there's no way I'd go back with the amount of piping we do on a daily basis.  And yes, your custom valves and fittings can be authored and added to the Content Center to be used with Tube & Pipe fairly easily.
So it all depends on the nature and amout of piping you need to do.
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cadtipstricks.wordpress.com//
Valued Contributor
trenthoskings
Message 4 of 6 (157 Views)
12-17-2012 12:04 PM in reply to: cbenner
Thanks Blair
Hi Chris
Thank you
Would you have a picture of your machines
Thanks again
Tony
blair
Message 5 of 6 (151 Views)
12-17-2012 12:21 PM in reply to: trenthoskings
We do commercial transport trailers, so most of our T&P is flexible lines.
Win7-64
Delta Tau Chi ΔΤΧ
Valued Contributor
trenthoskings
Message 6 of 6 (142 Views)
12-17-2012 01:51 PM in reply to: trenthoskings
very impressive
