What is the best way to draw pipe frame using "KEE KLAMP" connectors?
Pipe and tube or frame generator?
I suspect Tube & Pipe, but it would surely help to see what a Kee Klamp is. Can you post a picture of what you're trying to build?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Chris,
This is what they look like.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
I think for something like this, I (personally) would use tube & pipe. I would model, author and publish those connectors as if they were pipe fittings (elbows or tees etc). Then you could set up tube & pipe styles that used those "fittings", and build your frames using pipe routes. My opinion. I think it would be difficult to use FG and then have to work in all of the connectors around your end treatments using assembly constraints.
The connectors with a 90, plus the down leg might be a challenge.... but I think it would work.
Chris Benner
This is a catch 22. I am leaning more towards respectively disagreeing with Chris only for the simple fact that in frame generator you can have a skeleton sketch that is fairly easy to manipulate. That alone is the reason I would think to use FG.
Curious, is this pertaining to your other thread that I responded to?
http://forums.autodesk.com/t5/Autodesk-Inventor-General/Tube-frame-with-tube-connectors/td-p/4508623
Scott, I'm not disagreeing with you, but I am curious as to how you would work in the connectors? I'm having a hard time picturing that in my head using FG. I use both all the time, but I've never done a frame that wasn't welded, so maybe you have some insight I don't.
Chris Benner
Chris,
Seeing the FG is an assembly, what I am thinking is you have your one sketch that would be used to place the frame members, and a second sketch (which could look very similar to frame sketch) that would be used to place the connectors. One would overlay the other. Plus, once you have the frame sketch created, you do a file save as copy to create the second one for the connectors. Then parameters can be used to link the two sketches together so if a dimension changes on the frame sketch it would automatically update the connector sketch.
This might look like a lot of work, but once setup I think it could run pretty slick.
Scott, you obviously have experience and knowledge with Inventor than stars in the sky.
Me on the other hand is still a novice and wont dare going down your route as I have no idea of how you will even do something like that.
The idea Chris has sounds doable if I can just get the rigid route thing figured out.
Thanks for the advice guys.
But how would you terminate the tubes at the correct depth inside the connectors?
Sounds like you've been doing some top down design. 😉
I haven't toyed with that at all, we're strictly a floor up shop here.
Chris Benner
That is a lot of stars!!!!
Thank you though. It will come in time. We all started somewhere and grew.
Just remember that there are plenty of tutorials out there to instruct you.
Yeah, I have done top down several times.
That is how this would be done, and the terminations of the ends would be done in the sketch at the specific distance required by the connector.
Impressive.... I think I'll keep my head in the sand and stick to my bottom up design, at least for now. Old dogs, new tricks and all, you know.
Chris Benner
Hey Chris, if you can bring my head out of the sand with tube and pipe, surely you can do the same with FG.
After all, the air in the sand has to be pretty stail!!!
I use FG about every day. i just don't do full top down assembly design. We build our frame and then build up on that.
Chris Benner
@toger wrote:
Hi Chris
This is typically what I want to build.
Hi toger,
Just a quick reply to bring your attention to the fact that you can use a 3D solid as the basis of your Frame, in case you've not seen that before, see this link:
http://inventortrenches.blogspot.com/2013/08/use-3d-solid-edges-for-frame-generator.html
I hope this helps.
Curtis
Now that's impressive looking!!!
That looks a lot like what our other department creates.
Curtis,
That's something I may have to try once for some of our smaller frames.... just to see if I like that method. Thanks for sharing.
Chris Benner
