Inventor Forum
Tube design with loft
4 REPLIES 4
Henrik_Lo
387 Views, 4 Replies
HI
Need some help, how to make this tube with the loft command, it need to be round all along
and not flatting is out
Regards
Henrik
4 REPLIES 4
JDMather
in reply to: Henrik_Lo
@Henrik_Lo wrote:
...., how to make this tube with the loft command
Shouldn't that be a Sweep rather than a Loft?
The CADWhisperer YouTube Channel
Cadmanto
Henrik,
If you do searches on Youtube you will see plenty of tutorials on how to create these types of features.
Basically if you are doing a straight feature that has change between the base and the top then you need to use the loft feature.
If you have to create a snake type feature that may change shape along the curved path then you need to create a swepted feature.
I hope this helps you and good luck.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Henrik_Lo
in reply to: Cadmanto
HI both
Thanks for quick replay, I know about the sweep, but not that loft
Can’t do this type.
Regards
Henrik
JDMather
Can’t do this type.
Here is a Loft solution.
