HI
Need some help, how to make this tube with the loft command, it need to be round all along
and not flatting is out
Regards
Henrik
Solved by Cadmanto. Go to Solution.
@Henrik_Lo wrote:
...., how to make this tube with the loft command
Shouldn't that be a Sweep rather than a Loft?
Henrik,
If you do searches on Youtube you will see plenty of tutorials on how to create these types of features.
Basically if you are doing a straight feature that has change between the base and the top then you need to use the loft feature.
If you have to create a snake type feature that may change shape along the curved path then you need to create a swepted feature.
I hope this helps you and good luck.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
@Henrik_Lo wrote:
I know about the sweep, but not that loftCan’t do this type.
Here is a Loft solution.
