When I Populate Route, I do not know why the styles of Tube and Pipe I selected is different from the list in the browser. And the other problem is the diameter of weld neck flange is different from the pipe OD. Please see the attached screen shot and assembly file.
Please help me to solve the above problems.
Dear Mark
Thanks for yor reply. Yes, I edited the style and change the size as 4", but it cannot reflect to new size (4"). Please see the screen short attached.
I went through the tutorial of Tube and Pipe and I can change the size for the tutorial file. But mine cannot change the size. Could you please try changing the size of mine?
Activate your Route01 and then see what T&P style is active. The screenshot you show (in your first attachment) has only the parent assembly of the route active. The T&P style you've highlighted will have no effect on the T&P style of the ROUTE itself. Make sure you have the correct style active when you are in Route Mode...
EDIT: The attached is from one of the Autodesk's employees, Nicolas Xu, sorry if the name is misspelled. This has some good tips for T&P...
Really appreciate you help. I know where is my mistake. I changed the pipe size in Run01 instead of Route01.
Thank you very much
