Can somebody please tell me how to get the tube and pipe add-on? I do not already have it and I have not been able to find much information on how to get it. Thanks for your help.
Solved by DarrenP. Go to Solution.
We have the Autodesk product design suite and it is included in that.
Maybe you should contact your VAR to see about an upgrade.
you need at least product design premium or Ultimate
DarrenP
which design suite?
there no suite called autodesk design suite
these are the suites: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13456383
DarrenP
standard, premium or ultimate?
DarrenP
if its standard you don't get that add in
DarrenP
I'm guessing it is standard but I'm not sure how to find out. When I go to environments -- add-ins, I do not see tube & pipe listed.
So are you saying with the design suite it isn't there?
If so check the install to make sure that you did install it.
Like I said in my last posting We have the same as you and we have it.
[quote]
Like I said in my last posting We have the same as you and we have it.[/quote]
Yes, I have the product design suite 2013 Standard and it is not there.
read the comparsion: http://usa.autodesk.com/autodesk-inventor/compare/
the standard suite only comes with the base inventor package not inventor professional
DarrenP
you have to upgrade
DarrenP
I have Factory Design Suite Premium and I do not have the tube and pipe add-on. I thought I was supposed to have it with the Premium Suite. Am I missing something?
Tube and Pipe is only included in Inventor Professional..Inventor Pro is only included in FDS Ultimate...See this link:
http://www.autodesk.com/suites/factory-design-suite/included-software
It is also included in Product Design Suite Ultimate.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
