Hi everyone,
I had a request from one of our Engineers to give them an PCF file format so they can import into their Bentley software. I know this is a tube & pipe export option, however at the moment we are not using the tube & pipe module for what we are drawing up. We are drawing up a coil, consisting of buttwelded straight pipe then a 180 degree bend (purchased fitting), then another straight pipe and another 180degree bend, etc repeated over 6 times.. Is there anyway the tube & pipe style can be set up to use a 180deg bend? (i only see ability for 90 & 45deg) .?
Im using 2014 if that helps.
cheers 🙂
@buffs_star wrote:
I have all the items in need in the content centre, that's not the issue. I'm just not sure the tube and pipe module can handle buttwelded 180 deg bends, When i make a new style, all i see is the ability to choose 45 or 90 deg bends to place. how do i tell it i want a 180 deg?
You are correct that, in a T&P style, you cannot specify a 180 deg bend. However, you should be able to still model with them. You mentioned you had a length of straight pipe, then the bend, then more pipe etc. You can place your first 180 deg fitting right from the Content Center, constrain or ground it. Then create a route for the straight piece of pipe. Insert another 180 (never, ever copy and paste in T&P... trust me) and use the "connect" option to connect it to the last straight piece of pipe... create a new route on the end of that fitting... and so on until your coil shape is achieved. Does this help?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
