Here is my problem
When I start Tube and pipe environment, Inventor stops responding and I have to end the process manually.
If I start Tube and pipe environment in a new assembly, it's working. After I successfully create a Tube and pipe assembly in a new assembly, I have no more problems starting Tube and pipe environment in other assemblies. Each time I want to use Tube and pipe, I have to create one in a new assembly.
Inventor insallation is fresh with SP1
What is wrong ?
SP1 for which version of Inventor?
Can you describe your exact workflow? You have an assembly, in which you have already used Tube & pipe, and created a pipe run. What do you do next?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Inventor 2014
to make it works:
step 1
- create a new assembly
- save this assembly
- create a tube & pipe run
step 2
- open the assembly where I want to use tube & pipe
If I don't do the step 1, it's not working
Well, that does not seem right.
I know I've seen posts before about t&p and 2014... but a quick search revealed no solutions. I don't have 2014 to check this out on... but I suspect it may be an issue with this release. I would urge you to log a tech support case with this one.
One person said they changed somehting in the registry to fix their problem,.... I don't advocate that.
Chris Benner
