Just after a little bit of help with something.
In Tube & Pipe i have popped a valve into my route, it jumped to the pipe and the flanges automatically added which is fantastic. Now i want to move it to another part of the route. Without having to delete the valve and put a new one in, how do i move it? I did try to move the node, but it wouldnt move.
See the picture i have attached (and yes i know the flange size and valve size do not match).
Any help would be appreciated as its the one thing in the Tube&pipe module that realy drives me crazy and i know there has to be a proper way of doing this.
thanks
Anne.
Anne,
Is the valve contrained or just free floating?
If you have it dimensioned or constrained, you should be able to adjust those and the piping might change.
What version are you running?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Just looked at your picture.... in an instance like this the best thing to do is place a copy of the valve, and then delete the original one. You can move it within the sement it is in by simply editing the dimension on the route,... but to move it to another leg like this, it's easiest to just place another one, and delete the first. NOTE: Never, ever copy and paste fittings in T&P... ever. Bad things happen. Trust me. But.... you can pick the fitting inline, and go to the "Place Fitting" button on the tool bar. With a fitting highlighted, that button will place the exact same fitting without having to reopen the Content Center... just a bit of a shortcut.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
hi guys,
Thanks for the comments.
Sorry, forgot to mention im using inventor 2014 .
When i inserted the Valve i get a node on the pipe sketch and i can dimension to it if i want to. Keeping it in the same straight line isnt a problem, my issue is how to get that node moved to another segment of the pipe as per the picture i attached.
I cant seem to move the valve, or the node on the sketch.
Hope this clarifies what im trying to do.
Anne.
@cbenner wrote:Just looked at your picture.... in an instance like this the best thing to do is place a copy of the valve, and then delete the original one. You can move it within the sement it is in by simply editing the dimension on the route,... but to move it to another leg like this, it's easiest to just place another one, and delete the first. NOTE: Never, ever copy and paste fittings in T&P... ever. Bad things happen. Trust me. But.... you can pick the fitting inline, and go to the "Place Fitting" button on the tool bar. With a fitting highlighted, that button will place the exact same fitting without having to reopen the Content Center... just a bit of a shortcut.
I have been doing it that way, deleting the valve and placing a new one into the new segment of pipe, but if i have a drawing attached, i have to go and renumber, redimension it, which is a pain. We move heaps of items around on our gas trains until the project managers are happy. It ends up being a huge double handling of the work. Surely we should be able to pick components and moved them without having to delete. 😞
@buffs_star wrote:
hi guys,
Anne.
As I mentioned above, you can move the valve within a straight segment of pipe, but not around corners. I personally think that would be an AWESOME enhancement, but right now that just isn't possible. It does cause a lot of changes to be made to the drawings, yes.
Chris Benner
