Dear Helper !
First, I apologize for my English . Water machine techno I use Inventor . Problem is the following: the parts list a few rewrites item and ruined the tube & pipe assemblies.
For example: idw . drawing is opened :
" The View BOM used by this drawing is missing from the Following referenced assemblies . Balloons The Parts Lists and based on These assemblies reflect the last known values and will no longer update to changes in the referenced files.
Zagyvíz D90.iam "
I want to edit the main assembly of tube & pipe routes :
"The document is not to be activated adaptive in current context . T & P operations will be disabled . To edit it , please make it adaptive . "
When doing adaptive , then fall apart in the pathways , and I have to start over again the work. Where could be the error ?
Making a parts list that I use : " Structured BOM View ." What happens if I use " Structured ( legacy ) BOM View" ? Please help me , because a lot of extra work to do about that.
Please watch the attached pictures.
Thank you very much in advance:
Gergo Farkas
Hi and welcome to the forums.
It's difficult to see what happened to your assembly, but it looks like you made a Tube & Pipe assembly and then manually placed it into another assembly? Is this a copy of an existing Tube & Pipe assembly which exists someplace else? In order to use Tube & Pipe, the assembly will have to be made adaptive. But without knowing how you put it together, I can't tell what effect that is going to have. Can you describe your workflow a bit more?
As far as your parts lists go, it looks like you need to enable the BOM view in your drawing. Right click on the Parts List and select Bill of Materials. Then on the tab for Structured, right click to get the BOM view options. Question: Were the balloons on that sheet placed from an older BOM? If so, you may need to remove them before placing the new Parts List in order to clear any legacy data.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thanks for your response , Chris !
The work process in detail:
1 ) I create an assembly (standard mm iam) . This assembly contains the technological units are attached with tubes . Creates a pipe assemblies ( Tube & Pipe Runs )
2 ) A complete compilation I make a drawing ( .idw ) . In the drawing, I create a Part list , the views conferring with balloons . The Part list editor: identity of each element rewrites . Before saving the drawing indicates that you can not save some of the assemblys.
3 ) I open later edited into the main assembly. In this case, I can no longer edit the pipe assemblys. (Tube & Pipe application disabled). Recommends the program to me adaptive assemblies . If I do this , re- generate the routes but disintegrate in the geometric constraints . Can I do it all again ..
I'll send you some more pictures.
Thank you again !
I suspect there are several problems on top of one another that are causing your issues.
Would it be possible to pack n go your assembly and post it here? I may need to look at the whole thing to see what is going on.
Chris Benner
Hi Blair,
The OP was saying (I think) that trying to make the main T&P assembly adaptive screwed everything up. makes me think this was brought into the main assebly from outside as opposed to being creted in this session using T&P tools.
Hard to tell.
Chris Benner
That would be the only other way I can think that it would not be Adaptive. Trying to switch it to Adaptive means it's trying to locate the reference points used for it's construction.
OK, I share a project. The content center files are not included, they must be collected.
On the following link you can access the file (0003 - tosend.zip):
http://www66.zippyshare.com/v/14394989/file.html
The following files need to watch:
Balástya_épület_gépészettel.iam
1349_KT_TEG_0_GP_25_R0-Kezelt és öblítő víz.idw
1349_KT_TEG_0_GP_26_R0-Zagyvíz.idw
Thank you for all your intent to help!
Thank you for your post, Blair! You are right. Indeed it is the only way to restore the T&P assemblys. In such cases however, disintegrate routes, and to edit them again. We want realize that which job is causing this problem.
