Inventor Forum
Tube & Pipe Crashes Inventor in certain assemblies
2 REPLIES 2
963 Views, 2 Replies
Hi, I am having an issue with Tube & Pipe in a particular assembly. Every time I start up the tool Inventor (2014) crashes. I have used the tool since on other assemblies and it works fine.
I didn't want  to use the solution in this post yet since it does seem to only affect one assembly;
http://forums.autodesk.com/t5/Autodesk-Inventor/Inventor-2014-Tube-and-Pipe-tool-won-t-even-start/m-...
If anyone has any idea of what may be causing this that would be swell,
Thanks in advance.
2 REPLIES 2
cbenner
in reply to: cbenner
I hadn't used Tube&Pipe on this assembly before, It is a migrated assembly but it seems to be working now, thanks for the reply though.
