Hello
I will try to explane my problem a good as possible.
I have created a new workplane(used "offset from plane"), here i want to draw some lines so i can extrude that.
When im in that plane, i cant see the lines i drawing, nether take mesuerment or get the extrude function ut to do that.
So i hope you see my problem here, and understand me.
Hoping for some tips here..
Welcome to the forum.
When you say you can't see your sketched lines, do you have the grid on? If so you can turn them off under the sketch tab in the applications options in the tool tab.
Otherwise, can you post an image of what you are saying?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
