Hi Holly,
Welcome to the forum.
You never attached the photo ot image of the page you were refering to.
The other thought I have is usually the hole feature creates holes at a certain diameter at a certain depth.
Not through holes. If you are doing a through hole why not just create a through extruded cut and fillet that with one fillet feature.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Hi HolyB,
I think you might have caught an editing mistake in the book (if this behavior selection change is intentional) or possibly a bug in Inventor. This functionality did work in the past, but it looks like holes have been removed from support of the Feature option for Select Mode of the Fillet tool in your version.
The oldest version I have on this computer is Inventor 2010, but I can confirm that it did work then as shown here. But I'm not certain if this feature regression is intentional or is an oversight on the part of Autodesk. But I will inquire about it to see if someone can provide an answer.
My apologies for any confusion this has caused.
I hope this helps.
Curtis
