Inventor Forum
Trouble with breaking out a drawing
8 REPLIES 8
Message 1 of 9
gkmmartin
3157 Views, 8 Replies
Alright, I give up. I'm trying to break out a corner of this cone I'm working on to show that it's hollow and has an inner wall. Pretty simple I thought. But every time I press the breakout button I get "The view does not contain a sketch with a closed profile."
Again, it's a conical structure with a fixed wall thickness. I'm not sure what else I could use beyond the breakout button. Two pictures attached, one of the aft section and one of the detail that I'm trying to incorporate. What do you guys think?
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: gkmmartin
I think you don't have a sketch in the view.
Click on the view (the view boundary should highlight).
Now, without moving your mouse, hit S on the keyboard.
Sketch closed boundary.
Exit sketch.
Now try the Breakout View.
If you can't figure it out - attach your files here.
In my experience the most common problem beginners have is that they create the sketch at the sheet level rather than at the view level.
Message 3 of 9
SBix26
Put your cursor over the Break Out View tool, wait a few seconds, and you see this:
Message 4 of 9
gkmmartin
in reply to: SBix26
Hoy, well, I can't seem to figure it out. Maybe I'm not sure how to make a closed loop profile in a part like this? I'm kind of at a loss.
I attached a simplified version of the connector here, woudl that help?
Message 5 of 9
SBix26
Here's your drawing with a break-out view.  You simply create a view sketch and sketch a closed profile, then create the view.  In this case, I chose to make the depth "from point", and selected the tip and a depth of 0.
Message 6 of 9
JDMather
I don't see a sketch in your idw.
1. Click on the view - you should see red bounding box highlighted.
2. Hit s on the keyboard.
3. Sketch rectangle. Exit sketch.
4. Save and Attach your file here.
Message 7 of 9
gkmmartin
in reply to: SBix26
Good lord, that took for ever. Thanks for dragging me through the muck.
Message 8 of 9
JDMather
I wrote the same steps 5 days ago above in response #2?    Smiley Surprised
Message 9 of 9
gkmmartin
in reply to: JDMather
Right, it just took me a few days to realize where the sketch needed to be -- in the idw and not the ipt. Thanks to both of you for your help!
