Solved by CCarreiras. Go to Solution.
HI!
After you create the extrusion, the sketch will be embedded in the operation.
In the browser tree, You can open the extrusion by clicking in the + and you will find the sketch embedded.
Right mouse button and select "Share sketch"
Now the sketch can be shared with other operations.
If you wanna place a hole "by sketch", you can simply choose the point you need in the shared sketch (or remove clicking in Ctrl key).
After you use the sketch, you can turn off the visibility manually.
Did you find this reply helpful ? If so, use the Accept as Solution or Kudos - Thank you!
