Inventor Forum
trouble opening Inventor 2014
4 REPLIES 4
TRaViS1496
374 Views, 4 Replies
I installed everything last night and everything but Inventor works.  It gives me an error saying: "The application was unable to start correctly (0xc0000142). Click OK to close the application."  Any help?  I am using a new Windows 8 laptop so I don't see why it can open Designer but not Inventor.  I already ran a system scan and it didn't fix it.  Any help is appreciated.
4 REPLIES 4
Cadmanto
in reply to: TRaViS1496
What are your laptop specs?
Was this install a fresh and clean install with no previous versions loaded?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
TRaViS1496
in reply to: Cadmanto
Looking at the sticker here. AMD Dual-Core Processor E1-2500, 15.6" HD LED LCD, AMD Radeon HD 8240, 4 GB DDR3 L Memory, 750 GB HDD. No I have not had any previous versions installed.
blair
Install all the SP's and Hot-Fixes and updates for the SP's.
Try RMB on the Inventor icon and select the Run as Administrator.
Delta Tau Chi ΔΤΧ
TRaViS1496
in reply to: blair
Thanks for the help, greatly appreciated!
