I installed everything last night and everything but Inventor works. It gives me an error saying: "The application was unable to start correctly (0xc0000142). Click OK to close the application." Any help? I am using a new Windows 8 laptop so I don't see why it can open Designer but not Inventor. I already ran a system scan and it didn't fix it. Any help is appreciated.
Solved by blair. Go to Solution.
What are your laptop specs?
Was this install a fresh and clean install with no previous versions loaded?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Looking at the sticker here. AMD Dual-Core Processor E1-2500, 15.6" HD LED LCD, AMD Radeon HD 8240, 4 GB DDR3 L Memory, 750 GB HDD. No I have not had any previous versions installed.
Install all the SP's and Hot-Fixes and updates for the SP's.
Try RMB on the Inventor icon and select the Run as Administrator.
