Solved by DannyHubbard. Go to Solution.
Solved by camilo.lemos. Go to Solution.
Hi @JorisVwz and welcome to the Autodesk Community!
Hi and welcome to the Autodesk Community!
Please, disable your firewall and anti-virus programs and download the software from our Virtual Agent linked here (click on Download Links, choose product and version).
Please accept as solution if my post fully resolves your issue, or reply with additional details if the problem persists.
Thank you for the swift response, the files are downloading right now. What do I need to do once the download is complete?
Kind regards,
Joris
You're welcome!
Once the download is finished, all you have to do is double-click the downloaded file to begin the installation and then use the serial number you were provided with by the Education Community to activate the product.
Right, I got it installed now, but when trying to run Inventor, I get another error:
Inventor.exe - Application Error
The application was unable to start correctly (0xc0000142). Click OK to close the application.
Edit: I also got another error at some point, I'm not sure how to reproduce it, but it said something about reregistering
Make sure you have the latest updates for Inventor installed.
Danny
