I just recently got into Inventor, it is a very new program for me. I'm having problem unfolding this part, I been searching for solution but was unsuccessful even though there are many results out there.
I'm created the parts successfuly with no error, but when I try to create a flatten view it kept giving me error. I notice that some people try to use chamfer to resolve this issue but I tried with no luck. Also, I play around with the gap size and still get the error. Maybe someone here could help me out and and create the flat view for me so I could learn how to do it.
Thank you,
Bach
Solved by M.Peppel. Go to Solution.
I noticed that your first sketch isn't constrained.
You might start here http://home.pct.edu/~jmather/skillsusa%20university.pdf
I would not have used Extrude.
Most of work down to Corner4 could have been done with a single Contoured Flange feature.
I will try to post example in the next couple of days if someone else doesn't contribute a solution.
The CADWhisperer YouTube Channel
Thank you, I will wait for your version of this part. It is alway better to see other's method and also I want to see the most efficient way to create parts similar to this.
I had look into that PDF before, I found it while surfing. I will look into that constraint.
Best Regards,
Bach
Hi Bach,
your part does not unfold decause of the way you cut the notches 5;6; 9;10. The way they have been made you created an edge that does not allow the part to be unfolded.
HTH
Matthias
Hi Bach,
to prevent the problem described above you should better use the proper corner option from the flange dialogue (see screenshot).
Cheers
Matthias
M. Peppel,
I was playing with it this morning and using the unfold button, I was able to unfold everything except the flanges with the round corner.
Right now, I played around with the corner gap size at 0.1, round; and hopefully get something to work, so right now I keep playing with it and see if I can fix it.
Thanks for the replies,
Bach
If the radius of the round corner cuts is not important and the angle of the chamfers not critical - this is one easy solution.
I have another solution if those angles and radii are critical.
Thanks JD Mather, I couldn't open your drawing, I have Inventor 2011.
I remake the part using fold/unfold technique. It's a little bit longer but it work, I was able to fold out everything.
Here is the new drawing I made. Looking through my steps, what other methods would you suggest to reduce the steps.
Best Regards,
Bach
You should put 2011 in your signature so that everyone knows.
I will try to post a step-by-step when I get a chance.
But you can see my feature tree from this image
