I used a rectangular pattern to repeat a whole bunch of rectangles. There are a few lines near the top left of the sketch that I would like to trim. I've tried editting the pattern and unchecking Associative, but this results in a a lot of unconstrained items. Is there anyway I can keep the constraints and trim the pattern easily?
Hi Sanketh,
try selecting the elements of the pattern that you want to delete, right click and choose "suppress element/s"
Admaiora
I've tried that already, and unfortunately it doesn't work with these lines.
sanketh99 schrieb:Is there a way to use the grill tool on a sketch?
I've just seen problems with Grill feature some days ago. But can you show your actual IPT, instead of the DWG?
Walter Holzwarth
Yeah sorry about that. I accidentally uploaded the drawing file instead of the ipt file. I put the drawing in a block just fyi.
Hi! Certainly, it will be nice if the associative sketch pattern can allow some override in geometry. Can I ask why trimming has to happen on sketch level? Could you create geometry based on the sketch and then trim the geometry?
Thanks!
I think the trimming needs to be done in the sketch because the final product is the sketch itself. I don't plan on turing it into a 3d part.
I'm not sure how exactly I could do that.
