Inventor Forum
Trim to a Curved Member - Frame
6 REPLIES 6
dromani00
986 Views, 6 Replies
Anybody have a method of trimming a straight frame member to a curved on? an Example of a desired intersection is shown in red in the following sketch:
None of the built in frame end treatments likes this. i.e. I can select the straight member, but it will not recognise the curve.
THank you.
6 REPLIES 6
JDMather
in reply to: dromani00
What version of Inventor?
In earlier versions -
Edit the part in the context of the assembly.
Copy Object as Surface from the second part to use to edit the first part.
Attach your assembly here if you can't figure it out.  (only need the relevant files or make up a dummy assembly)
mdavis22569
in reply to: JDMather
What about using Copy Object and using the Sculpt commands I use that to trim items on a my conveyors I work on to match the curve of the bottom.
Mike Davis
dromani00
Hi there and thank you for the response.
I've got Inventor 2014.
I'd like brake your two steps down a bit more, please see if I have this
correct:
Part to edit: A frame assembly with an intersection between a curved
member (Item #1) and a straight member (Item #2).
The intersection is nearly perpendicular and I'm trying to use the
"Trim/Extend" option for the Frame set of the Design Tab.
1) Double Click Item1
2) Double Click Item 1 again.
3) Surface set appears on 3D Model Tab, but no copy as surface available:
And now I''m lost.
Thank you,
dromani00
Hi dromani00,
JDMather (*Expert Elite*) posted a new Reply in Inventor General
on 06-04-2014
02:22 PM:
Re: Trim to a Curved Member - Frame
| Accept as Solution
| Give Kudos
Autodesk Community sent this message to com02@donsplace.net
You are receiving this email because a new message matches your
subscription to a topic.
To control which emails we send you please go to, manage your
subscription & notification settings
or unsubscribe
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
JDMather
Part to edit: A frame assembly ....
You are editing a part, not an assembly.
1. In the context of the assembly right click on the part to edit and select Edit Part.
2. Click on the Copy Object tool and set the output to Surface.  Select the face of the second part.
3. Use the copied surface to Sculpt or Split your part.
Attach your assembly (or a representative assembly) here if you can't figure it out and end all doubt.
mdavis22569
can you post the set and you can see who it's done
Mike Davis
dromani00
Thank you for the info!
