Inventor Forum
Trim/Extend
2 REPLIES 2
869 Views, 2 Replies
Trim/Extend
I'm not sure whether this should be posted here or in the ideastation.
When using the frame generator's trim/extend command, if the length to be removed is greater than what remain, IV will remove the wrong half of the member.  Is this an issue with me or IV?
2 REPLIES 2
brendan.henderson
Inventor problem. Do a Lengthen/Shorten to make the length difference the other way around and then do the Trim/Extend.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Huh.  Thanks, Brendan.  I ran into this a couple weeks ago, wasn't quite sure what was going on.  Never thought to try the lengthen-shorten first.
Rusty
