Hi
How do i trim the round bars between each post and where the post meets the top round bar?
Should the sketch be more segmented?
Greg R
Solved by mdavis22569. Go to Solution.
Under the Design Tab ...
Use the Notch Command
Thanks Michael
I did originally use the Notch but it still does not remove the pipe from inside the upright posts.
Where the arrows are pointing is where i need the trim.The upright posts i do not want any pipe running through them.It is like having the horizontal pipes stop at the uprights so as not to pass through
Like this?
