Inventor Forum
Trig Disfunction ?
4 REPLIES 4
OutFrontPS
463 Views, 4 Replies
Trig Disfunction ?
On two computers the following incorrect answer  keeps showing up in iLogic but not on other computers.
Problem:
                Parameter(“x”) = a
                a = tan(180)
which gives x = 1.3386, when it should be x = 0
What might be the problem?
Has anyone run across this before?.
Riese Heemskerk
OutFront Portable Solutions
4 REPLIES 4
LT.Rusty
in reply to: OutFrontPS
The answer is correct, you're just working with radians, not degrees.
Rusty
OutFrontPS
in reply to: LT.Rusty
Thanks for your quick help. Is there a setting where I can change radians to degrees? The 'Document Settings' show that the default should be degrees. Best Regards, Riese Heemskerk OutFront Portable Solutions -- This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.
mrattray
No, iLogic always works in radians. You'll have to convert it in your code. If I remember correctly 360 degrees is 2*PI radians, so 180 degrees is PI radians.
Mike (not Matt) Rattray
OutFrontPS
in reply to: mrattray
Thanks very much for your help.
Appreciatively,
Riese
