This is annoying.
I've got this hinge working using translational constraints - but I don't seem to be able to apply an angle constrain to it to drive it.
I can't apply an angle constaint when using it as a flexible assembly either - and the flexible assembly keeps throwing an error to do with the translational constraints.
Anyone fancy digging in?!
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin | Twitter | Instagram | Facebook | Pinterest
Solved by JDMather. Go to Solution.
It works here if I set the workplanes through the axis and circle of revolution.
(the sketch circle isn't needed - I just included it to show the arc of rotation)
Have you installed all SP?
You pins are the same size as the holes/slots. No clearance - can't manufacture perfect geometry.
JD - first in the case! Thanks very much 🙂
I can't qute see what you've done there. Coud you elabotrate - or re-post your new version?
(I'm not going to manufacture this part - I just want to simulation the opening to work out whether my doors will bind when I use this hinge...)
I added two workplanes (one in each part) as shown and then placed a Directed Angle constraint in the assembly between the two workplanes.
I could then Drive Constraint.
I am using 2014.
@PaulMunford wrote:
.... - It's still a bit unreliable though.
You might need to increase the number of calculated positions, and the initial position is important.
I often create a "dummy" constraint (like Mate-Flush or Angle = 0) to set the initial position and then rename it Suppress This. If I need to get back to initial condition I unsuppress and then re-suppress this dummy positioning constraint.
