Inventor Forum
Translation of dwg to inventor
4 REPLIES 4
311 Views, 4 Replies
I am using inventor 2012 and am trying to import my MDT(2002) drawings but when I try the translation process I recieve an error message that says Mechanical Desktop must be installed. I currently of both Inventor and MDT installed and both operate correctly. Any suggestion on how to fix this problem?
4 REPLIES 4
JDMather
drawings or model?
can you attach an example dwg file here?
Actually I think you need MDT 2009 installed (it is free with your license).
in reply to: JDMather
THANK YOU FOR YOUR RESPONSE. HERE IS A DWG CREATED WITH WITH MECHANICAL DESKTOP 6.
FORGOT TO SAY THAT I AM TRYING TO IMPORT THE 3-D MODEL.
JDMather
Check this
http://beinginventive.typepad.com/being-inventive/mdt/
also,
you could save out the MDT file as a standard AutoCAD file or acis or step to open in Inventor.
