Here's the result in Inventor (file is 2008)
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
260-399-6615
Instructor/Author/Sr. App Engr.
AIP 11SP3, AIP 2008 SP1, PcCillin AV
HP zv5000 AMD64 ( modified)
Geforce Go 440, Driver: .8185, 2GB RAM
XP Pro SP2, Windows Classic Theme
"Dennis Jeffrey" wrote in message
news:5693066@discussion.autodesk.com...
Wally,
I think you misunderstand the use of the user parameters in imported MDT
parts. On revisiting your issue, you will see that all of the parameters
that are listed in the translated IPT file are tied to the original
mechanical desktop parameters. The original mechanical desktop parameters
are listed as user parameters, while the inventor of parameters are listed
normally. They are all required, and as a result they cannot be deleted.
If you want to change the part by
changing the parameters, then simply
change the user parameters and the inventor parameters should update.
I have attached a zip file of the cylinder itself, to show you an example.
260-399-6615
"Wally" <
diehlegrg@nospamdslextreme.com> wrote in message
news:5692710@discussion.autodesk.com...
Hi Dennis,
I simplified your file to a single part. View the *.jpg files of the
parameter tables and you'll see at the bottom User Parameters. In the first
table all of the translated MDT variables are present. The table is sorted
in the second image file, after which all mdt references in the equation
column are set to the variable constant. This allows the MDT variable in
the User Parameters part
of the table to be deleted by removing the
reference to the MDT tran
slation. The first time around I didn't notice
your part was actually an assembly, and I was able to delete the reference
to the Excel file in the User Parameters part of the table. When you go to
the last image file you'll see that all of the User Parameters are gone.
The only thing remaining is a link to the Excel file, which, for some
reason, I can't delete, even though it's not present in the part anywhere.
This represen
ts what I need to do with many part files. Unfortu
nately, this
is a time consuming process, and is why I'm searching for a shortcut, such
as a purge routine. K Johnson (below) indicates he has a routine that will
do this. I was unable to make certain of that from a visit to the web site
he supplied. If that gets clarified later I'll see if that will do what I'm
currently doing manually.
Thanks for taking the time to supply the files.
Wally
"Dennis Jeffrey" wr
ote in message
news:56
91978@discussion.autodesk.com...
Here's a MDT file with global parameters....
260-399-6615
wrote in message news:5691176@discussion.autodesk.com...
Can you post an example?
