Inventor Forum
Transition on a cylindrical backplate
13 REPLIES 13
Message 1 of 14
468 Views, 13 Replies
Hi All,
Is it possible to create a transition when the backplate shown in the picture is a cylinder?
I have tried several options, with 3Dpaths both nothing worked so far.
Maybe a workaround??
13 REPLIES 13
Message 2 of 14
CCarreiras
Hi!
What Picture?!
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 14
in reply to: CCarreiras
Message 4 of 14
Other question: Why can't I add .jpg or .png files?
Message 5 of 14
CCarreiras
Hi!
I don't know, sometimes is the size of the file, sometimes site issues, but... Post it directly:
CCarreiras
Message 6 of 14
I would like that view!
I just see a empty box....
Maybe if I use my tablet, but then the pictures are dificult..
Message 7 of 14
CCarreiras
Hi!
You mean, movement around inside, or outside a cylinder? Yes it's possible.
CCarreiras
Message 8 of 14
mpatchus
Are you trying to constrain something to the slot?
if so, create a boundary patch and constrain your part to it with a tangent constraint.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 9 of 14
Not really,
now I know how to attach a picture it is more easy to explain.
On attached picture the cylindrical path is visuable the roller has to follow that path around.
Message 10 of 14
in reply to: mpatchus
I tried that on the cylinder but that doesn't work..
Message 11 of 14
mpatchus
Something like this?
Inventor 2025 Beta
Message 12 of 14
Yes,
That is really what it should look like!
Message 13 of 14
mpatchus
Attached files for you to examine.
Inventor 2025 Beta
Message 14 of 14
That is it, and so simple!
I used the emboss feature to cut it out... That worked for the making of the part.
Thank you!
